rwill
#1 Posted : Monday, August 31, 2009 2:56:11 PM(UTC)
rwill
Dryer comes on and turns but won't heat. I have taken back panel off and cleaned the vent and checked the fan. Please help with the next step.
Thanks in advance
kayakcrzy
#2 Posted : Tuesday, September 1, 2009 4:44:51 AM(UTC)
kayakcrzy
Originally Posted by: rwill Go to Quoted Post
dryer comes on and turns but won't heat. i have taken back panel off and cleaned the vent and checked the fan. please help with the next step.
thanks in advance
let me help you out here. this is a everyday problem with your dryer. unplug the dryer, and take the back off. it will either be the element is broken, or there is a thermal fuse mounted on the top left side of the element housing, it is round and has 2 wires coming to it. or, your breaker is partially tripped. go outside, and flip the dryer breaker off an on a few times, and then see if it heats. if you have any questions, let me know. tom www.applianceeducator.com/parts.htm:cool:
SublimeMasterJW
#3 Posted : Tuesday, September 1, 2009 5:05:45 AM(UTC)
SublimeMasterJW
UserPostedImage
The small limit on the top(300F) will blow if the duct is stopped up
The bottom fuse is its cousin(250F), they are partners in crime.
When one fails both are bad and both come in a kit. The dryer
will however run even if these guys are open(bad).
kayakcrzy
#4 Posted : Tuesday, September 1, 2009 5:11:16 AM(UTC)
kayakcrzy
Originally Posted by: SublimeMasterJW Go to Quoted Post
UserPostedImage
There you go, give them pictures. Something other then a link, for these people to figure it out on there own. Guy's need to take a little more effort here with the help. If I had all day, and no job, I would help them all. ApplianceEducator.com
rwill
#5 Posted : Tuesday, September 1, 2009 2:25:13 PM(UTC)
rwill
Thanks for the help I just got home from my 10 hr a day job to lool at the responses. So I appreciate the help and sorry I didn't respond back quick enough for some people.
kayakcrzy
#6 Posted : Tuesday, September 1, 2009 2:59:40 PM(UTC)
kayakcrzy
If you needs us my man, we are here. Tom www.applianceeducator.com:eek:
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
