Jim Winkels
#1 Posted : Sunday, April 5, 2015 5:08:25 PM(UTC)
Jim Winkels
I have a Frigidaire dryer the heating element will not come on. I have tested all the limits and fuses all are good. The motor runs. I have 120 volt on each side of the element not 220 across the connections. There is a power resistor on the temp control not sure what the does. Can give me some advice. Timer? or am I missing something? Thank you much I am stumped.
Jim
#2 Posted : Tuesday, April 7, 2015 2:05:22 AM(UTC)
Parts for Frigidaire GLET1041AS1 Washer Dryer Combo - AppliancePartsPros.com
Here is the wiring diagram.
http://manuals.frigidaire.com/p...df/Webster/134134500.pdf
The resistor is used during auto cycles. In these cycles the timer motor is only powered when the heater is off. It then gets the full 240 volts. The resistor reduces this to 120 volts for the motor.
The first thing to check is the power going into the unit.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
prorepair
#3 Posted : Tuesday, April 7, 2015 2:20:42 AM(UTC)
prorepair
Hi,
I was also suffered from such situation. I have repair my washer from Appliance pro Inc. And now my washer is working as good as it should.
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
by ammo1md 2/14/2014 10:38:35 AM(UTC)
