Nmiles
#1 Posted : Monday, November 24, 2014 2:22:06 PM(UTC)
Nmiles
My mom has a Whirlpool Cabrio. Dryer stopped heating. We tested the thermal fuse and it test .3 on the ohm meter. The heater element tested at 9.8. Any ideas what else could be wrong before assuming it might be the board. We did get a a lot of lent that was clogging the vent.
Thanks...
Nancy
#2 Posted : Tuesday, November 25, 2014 12:38:03 AM(UTC)
Parts for Whirlpool WED6600VW0 Dryer - AppliancePartsPros.com
If the fuse you tested is the one on the blower, then it is not the one to check as it kills power to the motor not the heater.
The first thing to check is the power.
The motor/light etc. use half the line (120 volts) but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If OK
Unplug the unit and check the thermal cut-off and hi-limit thermostat an the heater assembly.
If blown then there are other things that should be checked before replacing them.
File Attachment(s):
WED6600.pdf (384kb) downloaded 11 time(s).
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
by ammo1md 2/14/2014 10:38:35 AM(UTC)
