AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer wont heat - element and fuses/limiters fine
Symptom: Everything works but no heat Troubleshooting: Element, Thermal Cut-off Fuse, High Limit T-Stat, etc. all have continuity, Good Blower airflow, door swithc is fine, timer rotates, 220v present to timer. Suspected timer issue (internal) after reading web reports. Inside of timer has a couple of blackened contacts that I suspect are the problem. When the blackened contacts are touching, I DO get continuity on the meter though. Wondering if they still break down under electrical load? I hate to buy a timer if perhaps blacked burnt looking contacts are normal on a 220v timer (W10185972). But I can't see any issues visibly elsewhere. ANy thoughts?
Dryer Repair
