Rescal
#1 Posted : Tuesday, August 18, 2015 5:23:15 PM(UTC)
Rescal
FOr the life of me I cannot find what wrong with this dryer. I tested the centrifugal switch and it has continuity when I click it, changed the thermostat, changed the thermo fuse, tested the thermistor, replaced the heating element, tested the voltage coming to the dryer and still dryer will not heat.
Can anyone help?
Rescal
fairbank56
#2 Posted : Wednesday, August 19, 2015 8:16:31 AM(UTC)
fairbank56
Assuming the dryer runs, just doesn't produce heat? Did you test the thermal cutoff? Other than that, looks like a faulty control board. A relay on the control board is used to turn the heat on/off. You could disconnect the red and black wires from the relay, make a PROPER jumper to jump them together and see if the heat works then. If it does, you need a new control board. Only do this for testing, do not try to use the dryer with those wires jumped out.
Eric
Rescal
#3 Posted : Wednesday, August 19, 2015 2:44:04 PM(UTC)
Rescal
Thanks Eric
YOu are good. I tried it and it started to work. Now, the question is do I have to change the complete control board of just the Relay?
Rescal
fairbank56
#4 Posted : Thursday, August 20, 2015 6:00:47 AM(UTC)
fairbank56
You will need to replace the board. The relay is soldered in and we don't know if the relay is the problem or the electronic components that control the relay is the problem. Check for a faulty solder joint where the relay is soldered in. That is a common failure point and you may be able to repair that if it's the problem and there isn't too much damage to the board.
You could put your finger on the relay case and see if you can feel a click when you turn the dryer on. If it clicks, then the electronics are probably ok and you could replace the relay if you have some soldering skills. Just Google search the relay part number to find a replacement.
Eric
Maytag dryer wont heat (Dryer Repair)
by tekwizard 6/19/2010 4:31:11 AM(UTC)
