Rcmutz
#1 Posted : Tuesday, October 6, 2015 5:16:21 PM(UTC)
Rcmutz
I have read various posts about failure to spin, but none that duplicate what I have.
The washer will cycle fine through all the wash and rinse cycles. When it gets to the spin cycle it will not spin. I have smelled burnt rubber, the motor hums. I checked the couple and it is fine. If I reach in and move the lower agitator, it will begin to spin up.
Any ideas on the problem or what to check next? Thanks.
Rcmutz
#2 Posted : Tuesday, October 6, 2015 5:38:43 PM(UTC)
Rcmutz
I should of mentioned that I had replaced the coupler about 8 months ago. I had found one of the pegs on the ground under the machine and thought the new one went bad, but As I said above, when I check it just now, it is fine.
Kenmore series 70 washer stopped mid-cycle and not starting (Washer Repair)
by bdcs64 3/28/2022 2:40:33 PM(UTC)
Kenmore Series 70 Washer- No Motor Activity (Washer Repair)
by smganger 1/24/2017 2:10:32 PM(UTC)
Kenmore Series 70 Dryer Slow Timer Problem (Dryer Repair)
by gamemaster14 1/29/2015 1:01:13 PM(UTC)
kenmore series 70 (Washer Repair)
by bmhagan 10/28/2013 12:40:00 PM(UTC)
Kenmore Series 70 Washer Repair (Washer Repair)
by Shadowraven 10/11/2013 9:08:35 AM(UTC)
Kenmore Series 70 Washer top not agitating (Washer Repair)
by juliepaloscio 6/8/2013 9:12:32 AM(UTC)
Kenmore Series 70 Elec Dryer, drum turns, no heat (Dryer Repair)
by lwfowler 1/22/2013 11:03:34 AM(UTC)
Kenmore Series 70 (Washer Repair)
by dwbaily 7/8/2012 2:19:54 PM(UTC)
Kenmore series 700 gas dryer (Low Heat) (Dryer Repair)
by jcspahr 12/19/2011 6:06:36 PM(UTC)
kenmore series 70 dryer repair (Dryer Repair)
by cdrted 10/26/2010 11:34:51 AM(UTC)
Kenmore Series 70 Electric Dryer - No heat (Dryer Repair)
by Mike N 10/25/2010 7:40:54 PM(UTC)
Dryer Not Drying Clothes-(kenmore series 70) (Dryer Repair)
by joolee123 10/11/2009 8:26:01 AM(UTC)
Kenmore Series 70 Washer will not Spin (Washer Repair)
by syeager 6/1/2009 9:38:51 AM(UTC)
Kenmore Series 70 (82372810) fills then drains instantly (Washer Repair)
by skibumintahoe 4/20/2009 11:40:55 AM(UTC)
kenmore series 70 washer will not agitate or spin have not found answer in other post (Washer Repair)
by industrial_elec 1/27/2009 7:10:15 AM(UTC)
