dwbaily
#1 Posted : Sunday, July 8, 2012 2:19:54 PM(UTC)
dwbaily
My son just purchased this used washer from a friend of his and it worked like once and then the drain hose popped off of it. He said it worked completely before the hose popped off. Was able to get the hose back on (clamp came off somehow) but now it will only fill up with water and agitate or run in the wash and rinse part of the cycle. No drain nor spin. Not sure what to check nor what would have caused it to stop working. Any suggestions? It does not drain nor spin in any of the cycles. Turned the knob a click at a time to try and get it to work and nothing. Any suggestions will be greatly appreciated before I have to call him a repair tech that he can't afford. Thanks all.
sidfink43
#2 Posted : Tuesday, July 10, 2012 5:56:34 PM(UTC)
sidfink43
I think you problem is the lid switch and that this problem is only a coincidence with your hose problem.
Here is the part
Part number: AP3100001
and there is a neat video that shows how to change it out. You can test the switch by by-passing it. The repair takes some time, but it is not difficult and if there are two people to do it then things will go a log smoother.
Good luck.
Kenmore series 70 washer stopped mid-cycle and not starting (Washer Repair)
by bdcs64 3/28/2022 2:40:33 PM(UTC)
Kenmore Series 70 Washer- No Motor Activity (Washer Repair)
by smganger 1/24/2017 2:10:32 PM(UTC)
Kenmore Series 70 (Washer Repair)
by Rcmutz 10/6/2015 5:16:21 PM(UTC)
Kenmore Series 70 Dryer Slow Timer Problem (Dryer Repair)
by gamemaster14 1/29/2015 1:01:13 PM(UTC)
kenmore series 70 (Washer Repair)
by bmhagan 10/28/2013 12:40:00 PM(UTC)
Kenmore Series 70 Washer Repair (Washer Repair)
by Shadowraven 10/11/2013 9:08:35 AM(UTC)
Kenmore Series 70 Washer top not agitating (Washer Repair)
by juliepaloscio 6/8/2013 9:12:32 AM(UTC)
Kenmore Series 70 Elec Dryer, drum turns, no heat (Dryer Repair)
by lwfowler 1/22/2013 11:03:34 AM(UTC)
Kenmore series 700 gas dryer (Low Heat) (Dryer Repair)
by jcspahr 12/19/2011 6:06:36 PM(UTC)
kenmore series 70 dryer repair (Dryer Repair)
by cdrted 10/26/2010 11:34:51 AM(UTC)
Kenmore Series 70 Electric Dryer - No heat (Dryer Repair)
by Mike N 10/25/2010 7:40:54 PM(UTC)
Dryer Not Drying Clothes-(kenmore series 70) (Dryer Repair)
by joolee123 10/11/2009 8:26:01 AM(UTC)
Kenmore Series 70 Washer will not Spin (Washer Repair)
by syeager 6/1/2009 9:38:51 AM(UTC)
Kenmore Series 70 (82372810) fills then drains instantly (Washer Repair)
by skibumintahoe 4/20/2009 11:40:55 AM(UTC)
kenmore series 70 washer will not agitate or spin have not found answer in other post (Washer Repair)
by industrial_elec 1/27/2009 7:10:15 AM(UTC)
