2 Pages<12
ljs.52
#11 Posted : Saturday, January 19, 2013 3:11:56 PM(UTC)
ljs.52
so it fits tight into the pump with no sloppiness, correct?
and could you tell me what the belt size is?
sidfink43
#12 Posted : Saturday, January 19, 2013 3:29:19 PM(UTC)
sidfink43
Yes, the shaft should fit tight into the pump.
Here is what Maytag says about the belts for this model, so you do need to make sure you have the right one.
"Reassembly of Pump and Belt
NOTE: Install pump and belt together. Drive belt MUST
be replaced with belt No. 40053602 for one and
two speed models; or 40053601 for some two
speed models and three speed models (special
clutch-type belt) for proper washer operation.
Refer to Parts Manual for proper belt part
number."
I would order a new belt from APP, if you have both your model number and serial number they should be able to get you the right one.
ljs.52
#13 Posted : Saturday, January 19, 2013 3:45:58 PM(UTC)
ljs.52
thanks for all your help.
ljs.52
#14 Posted : Sunday, January 20, 2013 9:06:50 AM(UTC)
ljs.52
Ok, the new motor didn't change things, now that I know what the belt size is supposed to be, it's stretched about 1 inch over size, is this something that could be the problem or is there another reason why machine doesn't seem to be rotating fast enough to pull more of the excess water out of the clothes. Running them through another spin cycle leaves them soppy wet.
sidfink43
#15 Posted : Sunday, January 20, 2013 12:38:10 PM(UTC)
sidfink43
Get the right belt. It will either fix things or you will be able to rule out the belt as a problem.
ljs.52
#16 Posted : Wednesday, January 23, 2013 3:45:41 PM(UTC)
ljs.52
Ccccccccccccccccccc
ljs.52
#17 Posted : Wednesday, January 23, 2013 5:12:07 PM(UTC)
ljs.52
Xxxxxxxxxxxxx
Guest (7)
Whirlpool washer wet clothes (Washer Repair)
by bobhickory 5/1/2020 9:48:31 AM(UTC)
wet clothes after spin (Washer Repair)
by ewade1601 8/24/2015 7:52:53 AM(UTC)
KENMORE 80 series wet clothes after spin cycle (Washer Repair)
by APPLIANCEDUDE1972 4/22/2015 4:05:46 PM(UTC)
Wet Clothes After Spin (Washer Repair)
by ZipAgent 4/21/2014 1:04:34 PM(UTC)
Wet Clothes (Washer Repair)
by Baldrick 3/25/2014 8:34:12 AM(UTC)
Maytag Atlantis wet clothes after spin (Washer Repair)
by Dkinyon 4/8/2013 10:05:33 AM(UTC)
Wet Clothes - End Of Cycle (Washer Repair)
by bigblanar 2/13/2013 11:20:43 AM(UTC)
GE Dryer Squeaks with wet clothes (Dryer Repair)
by boomerman58 1/14/2013 12:48:06 PM(UTC)
Whirlpool Duet Sport won't spin at high speeds... wet clothes (Washer Repair)
by Yellowtruck79 6/10/2012 7:31:44 PM(UTC)
wet clothes occasionally (Washer Repair)
by Timdezego 2/6/2012 3:24:02 PM(UTC)
wet clothes after final cycle (Washer Repair)
by BobBHo 12/13/2011 1:30:06 PM(UTC)
Washer will spin, but only when some of the wet clothes are removed (Washer Repair)
by yendor64 11/9/2011 12:35:29 PM(UTC)
wet clothes after finish cycle. (Washer Repair)
by carlos r 8/16/2011 4:27:56 AM(UTC)
by doitmayself 8/15/2011 11:31:09 AM(UTC)
by gilkelley 1/26/2011 4:14:16 PM(UTC)
2 Pages<12
