Purchased this unit used and immediately found the motor coupler needed replacing. Now everything seems to operate ...except for one thing...when I wash clothes using the NORMAL cycle the clothes seem to be much wetter when I put them into the dryer. I have checked to see if there is any real difference in the others cycles vs the NORMAL cycle and see no difference..any ideas?
Originally Posted by: gilkelley Purchased this unit used and immediately found the motor coupler needed replacing. Now everything seems to operate ...except for one thing...when I wash clothes using the NORMAL cycle the clothes seem to be much wetter when I put them into the dryer. I have checked to see if there is any real difference in the others cycles vs the NORMAL cycle and see no difference..any ideas? Gill, Does it drain a full tub of water in 90 seconds or less ? If not, suspect a weak,damaged drain pump or kinked,clogged drain hose. If the drain time is in range, suspect a slipping clutch assembly, Part number: AP3094537
