2 Pages12>
ljs.52
#1 Posted : Sunday, January 13, 2013 10:40:58 AM(UTC)
ljs.52
machine doesn't spin very fast and the clothes are saturated, :(
sidfink43
#2 Posted : Tuesday, January 15, 2013 4:28:10 PM(UTC)
sidfink43
Take off the front panel and check the belt for stretching or fraying, and then check the pump for any obstructions.
If everything checks out operate it with the front panel off and see if you can see what the problem is.
ljs.52
#3 Posted : Wednesday, January 16, 2013 2:32:45 PM(UTC)
ljs.52
the belt doesn't appear stretched, it's not frayed, the pump gets the water out, the only thing I noticed was that the motor didn't seem to reach maximum RPM. could this be a possibility?
sidfink43
#4 Posted : Wednesday, January 16, 2013 3:13:07 PM(UTC)
sidfink43
That would seem to be the problem. If it is agitating correctly it could be the timer or the wiring to the motor, but more likely it is the motor itself.
ljs.52
#5 Posted : Wednesday, January 16, 2013 3:54:22 PM(UTC)
ljs.52
I've ordered a new motor, will install this weekend. I'll give update when complete. Thank you for your help.
ljs.52
#6 Posted : Saturday, January 19, 2013 10:12:16 AM(UTC)
ljs.52
concerning the washer motor I am trying to replace in the nav6800aww model machine, seperating the pump from the motor shaft was tricky, seems there was some sort of sleeve on the end of the shaft to make it fit into the pump receiver tighter , well this part was corroded, anyway it finally did let go, but now there is a lot of play in the fit of shaft end into the pump, is there another part that I need or can I do some kind of alternate step to ensure a proper fit?
sidfink43
#7 Posted : Saturday, January 19, 2013 12:28:48 PM(UTC)
sidfink43
Okay, this is kind of a mystery since there is no sleeve on the motor shaft that I am aware of, and there isn't one in the parts diagram here.
04-Motor, Pump and Idler Assembly parts for Amana NAV6800AWW - AppliancePartsPros.com
I am wondering if the insert in the pump that the shaft goes into has come out, in which case you will need a new pump. If there is rust and it rust/welded itself on then the pump probably has a leak. In fact, it is possible that the pump was the problem in the first place. So I would get a new pump and try the old motor and if that works then return the motor. Otherwise I think I would replace both the pump and motor.
If you buy/bought the parts from this site they are returnable.
ljs.52
#8 Posted : Saturday, January 19, 2013 2:01:31 PM(UTC)
ljs.52
concerning the pump where the motor shaft inserts into is there more to it than just nylon is there supposed to be something else also that the shaft fits into?
sidfink43
#9 Posted : Saturday, January 19, 2013 2:46:13 PM(UTC)
sidfink43
No the shaft is designed to go right into the pump, there is no coupling or other piece that I am aware of.
ljs.52
#10 Posted : Saturday, January 19, 2013 3:09:02 PM(UTC)
ljs.52
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Whirlpool washer wet clothes (Washer Repair)
by bobhickory 5/1/2020 9:48:31 AM(UTC)
wet clothes after spin (Washer Repair)
by ewade1601 8/24/2015 7:52:53 AM(UTC)
KENMORE 80 series wet clothes after spin cycle (Washer Repair)
by APPLIANCEDUDE1972 4/22/2015 4:05:46 PM(UTC)
Wet Clothes After Spin (Washer Repair)
by ZipAgent 4/21/2014 1:04:34 PM(UTC)
Wet Clothes (Washer Repair)
by Baldrick 3/25/2014 8:34:12 AM(UTC)
Maytag Atlantis wet clothes after spin (Washer Repair)
by Dkinyon 4/8/2013 10:05:33 AM(UTC)
Wet Clothes - End Of Cycle (Washer Repair)
by bigblanar 2/13/2013 11:20:43 AM(UTC)
GE Dryer Squeaks with wet clothes (Dryer Repair)
by boomerman58 1/14/2013 12:48:06 PM(UTC)
Whirlpool Duet Sport won't spin at high speeds... wet clothes (Washer Repair)
by Yellowtruck79 6/10/2012 7:31:44 PM(UTC)
wet clothes occasionally (Washer Repair)
by Timdezego 2/6/2012 3:24:02 PM(UTC)
wet clothes after final cycle (Washer Repair)
by BobBHo 12/13/2011 1:30:06 PM(UTC)
Washer will spin, but only when some of the wet clothes are removed (Washer Repair)
by yendor64 11/9/2011 12:35:29 PM(UTC)
wet clothes after finish cycle. (Washer Repair)
by carlos r 8/16/2011 4:27:56 AM(UTC)
by doitmayself 8/15/2011 11:31:09 AM(UTC)
by gilkelley 1/26/2011 4:14:16 PM(UTC)
2 Pages12>
