Baldrick
#1 Posted : Tuesday, March 25, 2014 8:34:12 AM(UTC)
Baldrick
I've got a Samsung WF419AAW/XXA washer that's been leaving the clothes wetter than normal. I finally noticed that the there's a lot of vibration/thumping during the spin cycle. I think this is causing the washer to to end the spin prematurely.
From researching, it looks like I need a new drum/bearing assembly. Hence, a couple of questions:
Before I spend over $200, can I be pretty sure that this is the problem? Is there anything else I should check? I saw mentioned a VRT ring??? Also, I'm a DIY kind of guy. I've fixed many appliances like motors and pumps in my dishwasher, old clothes washer and dryer.
Is this something I could tackle? One website gives it a difficulty of 3 wrenches (out of 4) and I can't find much info on the repair.
Is it even worth fixing? It's got around 600 washes under it's belt.
Thanks!
Baldrick
#2 Posted : Tuesday, March 25, 2014 10:07:33 AM(UTC)
Baldrick
Just a follow up here...
I put the washer in service mode and started the Quick Spin Test with it empty. At around 500 rpm, it started to act unbalanced. It only went to 650 rpm before stopping. I'm sure this thing is supposed to go over 1000 rpm.
I also watched a YouTube video on checking the bearing and/or spider. I grabbed the inner drum and shook it around. Everything seemed tight and quiet.
BTW, it actually has 680 cycles on it.
avemaria
#3 Posted : Friday, March 28, 2014 2:04:44 PM(UTC)
avemaria
i'm not sure of your washer's exact setup but before you go to the more complex solutions, check your tub springs to make sure they're all still attached.. also if yours is like mine you'll have 2 sets of tub dampening pads.. if those are worn off or missing this will cause thumping.. only move on to other things if these things are in tact..
Whirlpool washer wet clothes (Washer Repair)
by bobhickory 5/1/2020 9:48:31 AM(UTC)
wet clothes after spin (Washer Repair)
by ewade1601 8/24/2015 7:52:53 AM(UTC)
KENMORE 80 series wet clothes after spin cycle (Washer Repair)
by APPLIANCEDUDE1972 4/22/2015 4:05:46 PM(UTC)
Wet Clothes After Spin (Washer Repair)
by ZipAgent 4/21/2014 1:04:34 PM(UTC)
Maytag Atlantis wet clothes after spin (Washer Repair)
by Dkinyon 4/8/2013 10:05:33 AM(UTC)
Wet Clothes - End Of Cycle (Washer Repair)
by bigblanar 2/13/2013 11:20:43 AM(UTC)
GE Dryer Squeaks with wet clothes (Dryer Repair)
by boomerman58 1/14/2013 12:48:06 PM(UTC)
by ljs.52 1/13/2013 10:40:58 AM(UTC)
Whirlpool Duet Sport won't spin at high speeds... wet clothes (Washer Repair)
by Yellowtruck79 6/10/2012 7:31:44 PM(UTC)
wet clothes occasionally (Washer Repair)
by Timdezego 2/6/2012 3:24:02 PM(UTC)
wet clothes after final cycle (Washer Repair)
by BobBHo 12/13/2011 1:30:06 PM(UTC)
Washer will spin, but only when some of the wet clothes are removed (Washer Repair)
by yendor64 11/9/2011 12:35:29 PM(UTC)
wet clothes after finish cycle. (Washer Repair)
by carlos r 8/16/2011 4:27:56 AM(UTC)
by doitmayself 8/15/2011 11:31:09 AM(UTC)
Wet Clothes (Washer Repair)
by gilkelley 1/26/2011 4:14:16 PM(UTC)
