sidoe
#1 Posted : Wednesday, December 10, 2008 5:54:17 PM(UTC)
sidoe
Hello, I purchased my dishwasher about a year ago from Lowes, just recently i noticed it was holding stagment water on the bottom. I thought the disposal may of been clogged however that was ruled out.
Then the second problem was that it would not start right away, for some reason it would go into delayed start regardless of what mode I pressed.
I'm not in the position to purchase a new unit and would hate to call a repairman out since I have had bad experiences in the past with them. Any help would be greatly appreciated. Thanks in advance.
v2k04
#2 Posted : Thursday, December 11, 2008 2:27:38 AM(UTC)
v2k04
Try unplugging it or killing power for a few minutes to see if that will re-set the control board for the delayed start problem, remove the front kickplate and check the pump and drain hose for obstruction disconnect from disposal drain in a bucket and see how much flow it has. you may just need a drain pump they normally get louder when they go bad
sidoe
#3 Posted : Thursday, December 11, 2008 10:28:34 AM(UTC)
sidoe
I did what you said and it does appear as if though the board did reset and now it is starting immediately however the water still does not appear to be draining and the pump is sounding louder than usual. I think you are on the money with your opinion as to what is wrong. How much would a pump cost more or less. Thanks soo much for your help.
v2k04
#4 Posted : Thursday, December 11, 2008 3:12:55 PM(UTC)
v2k04
my first post said 50 bucks but it didnt post............. anyway
PUMP ASSY - Made by: FRIGIDAIRE
Part Number: AP4019644
Warranty: One year
Our Price: $35.78
pretty close once ya add shipping
sidoe
#5 Posted : Saturday, December 13, 2008 11:29:45 AM(UTC)
sidoe
So i went to a local appliance shop and they had the drain pump in stock for 46 bucs out the door i came home and installed it and ran the dishwasher and with my fingers crossed opened the door after the cycle finished and unfortunately there is still water in the bottom. :confused:
v2k04
#6 Posted : Saturday, December 13, 2008 9:58:34 PM(UTC)
v2k04
Take it off and take it back tell them you didnt need it and pull the drain hose off and check it
Oven and display not working...please help. (Oven Repair (including Ranges and Cooktops))
by LJ44 2/5/2017 8:12:19 AM(UTC)
Please Help..Freezer is at 24-34 degrees (Refrigerator & Freezer Repair)
by spawnie69 7/21/2015 4:15:39 PM(UTC)
PLEASE help. Start device back-ordered. Need alternate part option! (Refrigerator & Freezer Repair)
by ChadJ55 3/12/2014 4:51:29 PM(UTC)
ctf1826ar magic chef not cooling at all. Please help. (Refrigerator & Freezer Repair)
by Dan-ctf1826ar 7/16/2013 2:06:28 PM(UTC)
Please Help..washer No Spin (Washer Repair)
by rnhib@att.net 3/12/2013 5:00:40 PM(UTC)
PLEASE help. Cant check parts (Dryer Repair)
by boandsusan 11/14/2012 9:03:49 AM(UTC)
FF code, Warm Air only, Fridge will not get cold at all. Please HELP. (Refrigerator & Freezer Repair)
by vaderrules1972 7/13/2012 1:44:15 PM(UTC)
Fills but won't advance unless you bang on the lid. Today it's dead. Please help. (Washer Repair)
by Debra Torres 6/21/2012 4:29:06 PM(UTC)
Please Help...Freezer/Refrigerator Not Cold.... (Refrigerator & Freezer Repair)
by SolomonMan 3/26/2012 1:53:14 PM(UTC)
Please help. 3 kids and loads of wasing (Washer Repair)
by clive 3/19/2010 2:38:54 PM(UTC)
Please Help. Water Valve Issue (Refrigerator & Freezer Repair)
by ChrisMNS.Ut 8/24/2009 9:02:02 AM(UTC)
please help..... (Washer Repair)
by bigdaddyj 3/11/2009 3:00:03 PM(UTC)
Please Help....Microwave stopped working (Microwave Repair)
by unc25 3/2/2009 6:46:55 AM(UTC)
Please Help. Frigidaire PLEC36S9ECC Cooktop. (Oven Repair (including Ranges and Cooktops))
by bradford 12/24/2008 7:50:18 AM(UTC)
Please help...Refrigerator problems!!!!! (Refrigerator & Freezer Repair)
by bmj2005 12/3/2008 6:02:18 PM(UTC)
