2 Pages12>
kstalker1974
#1 Posted : Wednesday, November 18, 2009 11:08:48 AM(UTC)
kstalker1974
Switched the plug in the back from a four to a three and turned on then "pop" now it won't start.
gabe_1981
#2 Posted : Wednesday, November 18, 2009 11:16:18 AM(UTC)
gabe_1981
Please be sure to check that your cord connected at the dryer has nutral in the middle or at the white wire ... Then make sure no leads are not grounded to the dryer frame or eachother ... Then reset your breaker at the breaker pannel.
kstalker1974
#3 Posted : Wednesday, November 18, 2009 11:24:39 AM(UTC)
kstalker1974
Done all that and still will not turn on
gabe_1981
#4 Posted : Wednesday, November 18, 2009 11:35:43 AM(UTC)
gabe_1981
Tell me about this pop you herd ... how long did the dryer run after replacing the cord ... I say all this to say that GE puts a switch on the belt idler and if it was your belt that snapped and made the pop sound that switch will be in the open position and your dryer will not start even though it has 240 volts goin to it.
kstalker1974
#5 Posted : Wednesday, November 18, 2009 11:47:53 AM(UTC)
kstalker1974
it was a quick pop like a breaker going off. checked breakers and nothing fliped off. then just would not start again
gabe_1981
#6 Posted : Wednesday, November 18, 2009 11:51:38 AM(UTC)
gabe_1981
Alot of times when a breaker pops, visually it will look as if it didn't pop ... To be on the safe side, flip the breaker back and forth to make sure it resets.
kstalker1974
#7 Posted : Wednesday, November 18, 2009 11:55:15 AM(UTC)
kstalker1974
I did check them all, still nothing
gabe_1981
#8 Posted : Wednesday, November 18, 2009 12:00:41 PM(UTC)
gabe_1981
If you have a volt meter you can check for 240 at the wall outlet ... you should get 240 across the two diagnal inlets and 120 from each diagnal to L shape inlet.
kstalker1974
#9 Posted : Wednesday, November 18, 2009 12:05:08 PM(UTC)
kstalker1974
I had an electrician hat when he was here fixing my light switched the other day t he just did not know anything about dryers. How do you get the back off to check the drum to see if that switch is open?
gabe_1981
#10 Posted : Wednesday, November 18, 2009 12:19:20 PM(UTC)
gabe_1981
If you open the dryer door and look up in the door housing you will see two screws ... If you remove them two screws you will be able to lift the dryer top exposing the belt around the drum ... If the belt is missing you know thats the problem ... You can also check the door switch at the same time ... With the dryer unplugged you can test to see if the switch is open when the door is closed.
Guest (8)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 2/6/2024 7:34:41 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Washer cycle won't start, motor just buzzes (Washer Repair)
by Guest 4/6/2023 4:46:53 PM(UTC)
Samsung DV42H5200EW/A3 Dryer makes loud buzzing noise and won't start unless (Dryer Repair)
by bvon 4/3/2023 9:46:22 PM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Samsung washing machine won't start (Washer Repair)
by Guest 11/14/2022 7:56:18 AM(UTC)
Maytag MDBH985AWS Won't Start Motor Humming (Dishwasher Repair)
by pdmac00 10/11/2022 12:48:23 PM(UTC)
Whirlpool WTW7500gc0 has power but won't start (Washer Repair)
by Guest 2/27/2022 2:52:51 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
dryer WED8300swo won't start (Dryer Repair)
by Guest 10/26/2021 10:24:13 AM(UTC)
Maytag LAT9600AAW Won't Start (Washer Repair)
by Guest 8/28/2021 6:11:33 AM(UTC)
2 Pages12>
