have a 9 yr old admiral washer. will fill & agitate. when comes time to spin, won't drain. some leaking (not very much) on floor. spin timer several times & when it does drain, makes a squeeching sound & won't kick into spin cycle. bad drain pump? bad motor (for spin)? bad timer? please help !
Leanthe the washer back take the belt off. Then try turning the pump by hand.
taken to shop this morning. will find out from them later today (wouldn't you know goes down on holiday...). will find out from shop what they say. may end up buying new since is 9 yrs old. i still think might be timer, pump and/or motor. thanks for help.
call from service guy. tub to water pump had leak in it. that caused some water to leak on floor & also onto belt. the belt would slip & not work properly. may need to check others that have same problem. this one cost me 25.00 for service (dropped off myself & not pay 75.00 for service call to my house) and new hose was 10.00.
