I have an admiral washer that stopped draining and cycling,but the motor humbs.
Groups: APP Team
Hi. Disassemble the washer and take the drain pump off the motor. See if it's jammed. disconnect the motor from the transmission lay it on the ground and start without the load. Check the start capacitor Part number: 8572717
