bamadadof2
#1 Posted : Monday, December 31, 2007 3:43:34 AM(UTC)
bamadadof2
have a 9 yr old admiral washer. will fill & agitate. when comes time to spin, won't drain. some leaking (not very much) on floor. spin timer several times & when it does drain, makes a squeeching sound & won't kick into spin cycle. bad drain pump? bad motor (for spin)? bad timer? please help !
okbobcats
#2 Posted : Monday, December 31, 2007 4:38:01 AM(UTC)
okbobcats
Leanthe the washer back take the belt off. Then try turning the pump by hand.
bamadadof2
#3 Posted : Monday, December 31, 2007 6:11:54 AM(UTC)
bamadadof2
taken to shop this morning. will find out from them later today (wouldn't you know goes down on holiday...). will find out from shop what they say. may end up buying new since is 9 yrs old. i still think might be timer, pump and/or motor. thanks for help.
bamadadof2
#4 Posted : Monday, December 31, 2007 10:11:37 AM(UTC)
bamadadof2
call from service guy. tub to water pump had leak in it. that caused some water to leak on floor & also onto belt. the belt would slip & not work properly. may need to check others that have same problem. this one cost me 25.00 for service (dropped off myself & not pay 75.00 for service call to my house) and new hose was 10.00.
Guest (5)
Admiral washer squeaks during agitation (Washer Repair)
by kukayaker 10/10/2014 10:47:17 AM(UTC)
Admiral Washer Machine Water Temp Not Working Correctly (Washer Repair)
by CRAIG1978 7/26/2014 11:08:17 AM(UTC)
Admiral washer drains, but won't spin in wash cycle (Washer Repair)
by WJG 7/19/2014 2:32:36 PM(UTC)
Admiral washer just fills (Washer Repair)
by 73buick225 3/2/2014 3:26:31 PM(UTC)
Admiral washer pls help (Washer Repair)
by nomifish07@aol.com 1/25/2014 12:46:17 PM(UTC)
Admiral washer: Cold water only on warm setting (Washer Repair)
by divemasterjt 11/20/2013 7:18:09 PM(UTC)
Admiral Washer: howling, spinning, smoking... (Washer Repair)
by Noobzilla 7/17/2013 9:03:46 PM(UTC)
Admiral Washer Spin Cycle problem (Washer Repair)
by nckomorowski 10/21/2012 8:15:37 AM(UTC)
admiral washer (Washer Repair)
by jared parsons 9/14/2012 6:33:39 AM(UTC)
by tvanloon43 7/12/2012 7:17:42 AM(UTC)
Admiral washer leak (Washer Repair)
by llimer 3/20/2012 6:10:55 AM(UTC)
Admiral washer agitates during spin cycle (Washer Repair)
by Trenchfoe 3/4/2012 6:55:13 AM(UTC)
Admiral washer agitates but wont drain. (Washer Repair)
by smitty225 2/28/2012 12:04:17 AM(UTC)
Admiral washer wont fill (Washer Repair)
by jay1437 1/15/2012 1:35:43 PM(UTC)
Admiral washer machine (Washer Repair)
by 01queenie01 5/8/2011 9:14:49 AM(UTC)
