CRAIG1978
#1 Posted : Saturday, July 26, 2014 11:08:17 AM(UTC)
CRAIG1978
My Admiral Washer Machine Is Putting The Wrong Temperature Water Into The Fill Tub. When I Select The Cold Cold Setting Temp The Cold Begins To Fill Then After A Few Seconds The Cold Stops Filling And The Hot Water Begins To Enter. It Sporadically Will Alternate From Cold To Hot Without Me Choosing Hot Water And Hot Water Is Favored By The Washer And Not Me. What I Did Was Bypassed The Hot Water Valve From The House And Installed A Y Splitter Hose So I Have Only Cold Water Going Into The Hot And Cold Ports Of The Water Inlet Valve At Rear Of Washer. I Can Hear And See That Even Still Just Having Cold Going In The Washer Is Still Trying To Put Hot Water In Since The Hot Water Has A Reduced And Slower Flow Rate Than The Cold? Is This Normal And I Have Cleaned The Screens On The Water Inlet Valve But Have Not Checked The Ohm Continuity Of The Valve Or Temp Switch? Which Part Or Parts Could Be Bad. Thanks Craig
fairbank56
#2 Posted : Saturday, July 26, 2014 12:17:04 PM(UTC)
fairbank56
Cold wash is regulated to 70° by the temp control, so yes, it will cycle hot water on to achieve that temperature. Rinse temp should be cold only. If it is cycling the hot water on in rinse, then I would replace the temp control.
Eric
