Rick1
#1 Posted : Sunday, January 24, 2010 1:34:07 PM(UTC)
Rick1
Wtaer is hot put high limit reset keeps popping. once reset heats water ffine but will pop again?
Rick1
#2 Posted : Sunday, January 24, 2010 1:37:38 PM(UTC)
Rick1
Originally Posted by: Rick1 Go to Quoted Post
Water is hot but high limit reset keeps popping. once reset heats water fine but will pop again?
nnnnnnnnnn
John @ Fischers
#3 Posted : Monday, February 8, 2010 5:07:56 PM(UTC)
John @ Fischers
Probably lower t-stat problem if your still popping top stat. if you can, actually measure the temp of the water, or maybe you notice the water is hotter than normal?
Check water temp. If too hot versus your settings, replace lower stat and monitor.
gas hot water heater flame sensor (General Talk)
by normpete 1/21/2022 9:10:29 AM(UTC)
Electric Hot Water Heater (Forum Announcements)
by paul gesche 9/7/2019 9:39:25 AM(UTC)
hot water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by johna56 12/26/2017 11:32:44 AM(UTC)
Ever decreasing hot water throughout house- Hot Water Heater (Heating, Ventilation, and Air Conditioning (HVAC))
by Boiler20 6/30/2014 7:25:33 PM(UTC)
Hot water heater anticipator (Heating, Ventilation, and Air Conditioning (HVAC))
by jbili 11/30/2011 3:46:02 PM(UTC)
Replacing gas hot water heater only for higher efficiency.... (Heating, Ventilation, and Air Conditioning (HVAC))
by Olives 7/21/2010 4:15:57 AM(UTC)
Gas Hot Water Heater Broken? (Heating, Ventilation, and Air Conditioning (HVAC))
by bmyu 12/26/2009 6:12:22 AM(UTC)
40 Gal. Dual Element Electric Hot Water Heater (Heating, Ventilation, and Air Conditioning (HVAC))
by Teager 9/11/2009 1:21:26 PM(UTC)
hot water heater (General Talk)
by conjp57 10/17/2008 8:47:09 PM(UTC)
bosch tankless hot water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by artie in miami 8/17/2008 1:12:00 PM(UTC)
hot water heater (Forum Announcements)
by angidale 8/12/2008 4:40:04 PM(UTC)
Hot Water Heater won't stay lit. (General Talk)
by bulll 5/20/2008 8:51:10 AM(UTC)
wiring hot water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by kyle pennsylvania 12/29/2007 2:23:19 PM(UTC)
