Rick1
#1 Posted : 15 years ago
Rick1
Wtaer is hot put high limit reset keeps popping. once reset heats water ffine but will pop again?
Rick1
#2 Posted : 15 years ago
Rick1
Originally Posted by: Rick1 Go to Quoted Post
Water is hot but high limit reset keeps popping. once reset heats water fine but will pop again?
nnnnnnnnnn
John @ Fischers
#3 Posted : 15 years ago
John @ Fischers
Probably lower t-stat problem if your still popping top stat. if you can, actually measure the temp of the water, or maybe you notice the water is hotter than normal?
Check water temp. If too hot versus your settings, replace lower stat and monitor.
gas hot water heater flame sensor (General Talk)
by normpete 3 years ago
Electric Hot Water Heater (Forum Announcements)
by paul gesche 5 years ago
hot water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by johna56 7 years ago
Ever decreasing hot water throughout house- Hot Water Heater (Heating, Ventilation, and Air Conditioning (HVAC))
by Boiler20 11 years ago
Hot water heater anticipator (Heating, Ventilation, and Air Conditioning (HVAC))
by jbili 13 years ago
Replacing gas hot water heater only for higher efficiency.... (Heating, Ventilation, and Air Conditioning (HVAC))
by Olives 15 years ago
Gas Hot Water Heater Broken? (Heating, Ventilation, and Air Conditioning (HVAC))
by bmyu 15 years ago
40 Gal. Dual Element Electric Hot Water Heater (Heating, Ventilation, and Air Conditioning (HVAC))
by Teager 15 years ago
hot water heater (General Talk)
by conjp57 16 years ago
bosch tankless hot water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by artie in miami 17 years ago
hot water heater (Forum Announcements)
by angidale 17 years ago
Hot Water Heater won't stay lit. (General Talk)
by bulll 17 years ago
wiring hot water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by kyle pennsylvania 17 years ago
