When On Spin It Does't Drain Do I Need A New Pumo Or Pressure Switch?
The first thing to do is the check the pump and drain hoses for an obstruction. If this is not the problem then you will have to do some testing to identify the culprit. This service manual will show you how. If you need info about your model specifically it is discussed at the back. http://www.servicematters.com/m...ibrary/docs/16010061.pdf
