malakye
#1 Posted : Sunday, March 5, 2017 1:18:25 PM(UTC)
malakye
have a whirpool ultimate care 2 the washer was agilting but will not spin to get the water out of the clothes it will drain had someone replace the coupler but still wont spin if its to much weight unless you open the lid and push it first or remove some clothes I have the transmission and motor out what should I be looking for to figure out the problem the transmission or the motor or clutch other than transmission was wet cant see anything visualy wrong and I bought the washer used so not sure if the transmission has leaked out all the fluid unless I take it apart
brobriffin
#2 Posted : Monday, March 6, 2017 4:31:47 PM(UTC)
brobriffin
Man
Typically the problem winds up being the transmission is not staying in neutral while the water is being pumped out.
This in turn will cause the coupling to break.
It will also cause the clutch to slip and fail.
I suggest (without further info) that you either replace the transmission (or rebuild it) and replace the clutch and coupling as well.
The trany is pretty reasonable
Whirlpool 3360629 Neutral Drain Transmission - AppliancePartsPros.com
Whirlpool 285785 Clutch Assembly - AppliancePartsPros.com
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Replacing these parts will give you several more years of service.
malakye
#3 Posted : Thursday, March 9, 2017 6:59:24 PM(UTC)
malakye
thank you very much was the transmission
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
Whirlpool LTE6234DQ2 Wont Spin (Washer Repair)
by kelgun 12/7/2023 2:53:34 PM(UTC)
my fully automatic washer,(top loader) WONT SPIN (Washer Repair)
by johnsail2000 4/14/2023 8:51:18 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
GE top load wont spin (Washer Repair)
by NOELLE.EUAN 10/15/2017 5:03:37 PM(UTC)
Hotpoint wont spin or drain (Washer Repair)
by Snowostrich 7/1/2017 2:53:32 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
Kenmore wont spin or drain. no noise. Lid switch does click. (Washer Repair)
by DCAJR1 8/17/2016 12:09:50 PM(UTC)
Wont spin on *some* settings (Washer Repair)
by merkman 7/18/2016 7:15:38 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytage wont spin (Washer Repair)
by Mike055 12/10/2015 11:15:41 AM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
