I have a problem with my washer , the tub fills up when it is time to drain it seem to over flow all over the floor it seems to be overflowing from the tub we changed the timer we changed the lid switch the belt it has a new transmission that was put in a few years ago I changed the load from extra large to large and it didnt seem to overflow till just now HELP I HAVE NO IDEA WHAT THE PROBLEM COULD BE thanks Greg:
Try cleaning out the tube that goes to the pressure switch. If that doesn't fix things change out the pressure switch. If you buy the part from this site and it does not fix the problem you can return it.
Were is the pressure switch and what does it look likt The tone is clear And how much is the part
