gapjan
#1 Posted : Sunday, November 1, 2015 3:13:22 PM(UTC)
gapjan
I have a problem with my washer , the tub fills up when it is time to drain it seem to over flow all over the floor it seems to be overflowing from the tub we changed the timer we changed the lid switch the belt it has a new transmission that was put in a few years ago
I changed the load from extra large to large and it didnt seem to overflow till just now
HELP I HAVE NO IDEA WHAT THE PROBLEM COULD BE
thanks Greg:
sidfink43
#2 Posted : Wednesday, November 4, 2015 12:06:43 PM(UTC)
sidfink43
Try cleaning out the tube that goes to the pressure switch. If that doesn't fix things change out the pressure switch. If you buy the part from this site and it does not fix the problem you can return it.
gapjan
#3 Posted : Friday, November 13, 2015 7:47:13 AM(UTC)
gapjan
Were is the pressure switch and what does it look likt
The tone is clear
And how much is the part
sidfink43
#4 Posted : Friday, November 13, 2015 9:06:24 AM(UTC)
sidfink43
Here is a link to the parts diagram with your part.
Whirlpool 21002031 Switch, Water Level - AppliancePartsPros.com
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
