I just replaced the bearings of my Maytag Washer MAH5500BWQ. I put everything back together and ran a test cycle. It would go down to 1 minute then back up to 15minutes and keep doing that until I manually turn it off. I cleaned out the drain hose and now it is stuck on 1 minute with what I believe to be the draining noise. I have to manually turn it off otherwise it will keep draining at 1 minute timer left. Is this a drain pump or control board error? Laundry inside is still damp. Thanks! Edited by user Sunday, September 10, 2023 4:02:36 PM(UTC)
| Reason: added more details
