JLH69
#1 Posted : Saturday, April 5, 2014 1:10:19 PM(UTC)
JLH69
Both ovens are not heating. Press the start button for either oven and everything looks normal but neither oven will heat. Lights and fan come on, temperature window says Lo, but no heating at all. Will note that I recently changed out my breaker box. Any chance that changing the box could be related?
#2 Posted : Saturday, April 5, 2014 2:20:53 PM(UTC)
See the attachment for a tech sheet. It is the closest I could find DHW9.
I am assuming the the Lo means that the ovens are in preheat and never come ready.
I would check the power as the most likely cuprit since you mentioned the breaker box.
It is the 240 volts (L1 to L2) that is important as that is the votage that drives the heating elements.
File Attachment(s):
KEBS277.pdf (379kb) downloaded 4 time(s).
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 12/13/2020 11:44:10 AM(UTC)
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
oven won't heat, replaced element seems to have caused more problems (Oven Repair (including Ranges and Cooktops))
by kepu 1/8/2019 10:48:17 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
Gas Oven won't heat but broiler and burners work fine (Oven Repair (including Ranges and Cooktops))
by Melissabrooks 3/4/2018 6:42:44 AM(UTC)
Oven won't heat (Oven Repair (including Ranges and Cooktops))
by mbreihan59 2/5/2018 5:48:30 PM(UTC)
Lower Oven won't heat (Oven Repair (including Ranges and Cooktops))
by akai230 11/7/2016 5:26:07 PM(UTC)
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 11/24/2015 7:23:04 AM(UTC)
GE Profile Convection Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by igotboost 8/7/2015 10:38:00 AM(UTC)
Ikea Nutid Wall Oven won't heat (Oven Repair (including Ranges and Cooktops))
by Triciav48 6/29/2015 6:36:33 AM(UTC)
Frigidaire oven won't heat (Oven Repair (including Ranges and Cooktops))
by scottrandel 6/28/2015 4:52:44 PM(UTC)
Lower Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by FrustratedGeminiOven 3/15/2015 10:45:08 AM(UTC)
by trisha57 4/28/2014 10:23:33 AM(UTC)
Top oven won't heat after self cleaning was done (Oven Repair (including Ranges and Cooktops))
by Dede B 4/6/2014 2:22:53 PM(UTC)
Hotpoint Electric Oven Won't heat (Oven Repair (including Ranges and Cooktops))
by krausjw 2/22/2014 10:14:42 AM(UTC)
