mbreihan59
#1 Posted : Monday, February 5, 2018 5:48:30 PM(UTC)
mbreihan59
I recently used the self clean feature on my Whirlpool electric range. About three quarters if the way through the cycle I heard a loud pop and I'm fairly certain I saw a tall flame shoot out the back right burner for just a second. I saw no other irregularities as the cycle finished. The next time I went to use my oven, I selected bake > start and the display read 100 degrees and that the oven was preheating. However the over never gets hot. The coils do not heat up. Everything else on the oven works just fine (display/burners/etc.).
After removing the back panel I noticed the piece in the attachment looked like it had flame damage but I cannot find what this piece is or if it's something a pro should look at. Advice?
Thank you
mbreihan59 attached the following image(s):
ThatGuy
#2 Posted : Tuesday, February 6, 2018 1:56:09 AM(UTC)
ThatGuy
The part you are wondering about is the back end of a light socket. What you are seeing on it are fumes and residue from self cleaning. You apparently had a lot of grease and combustibles inside and at some point they burst into flames and smoke came out wherever it could. The light socket has nothing to do with heating.
I'm guessing that the extra heat caused the thermal fuse to open. From the back its just to the right of the light socket. Watch the video on the same page.
Whirlpool WP3196548 Thermal Fuse - AppliancePartsPros.com
UserPostedImage
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 12/13/2020 11:44:10 AM(UTC)
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
oven won't heat, replaced element seems to have caused more problems (Oven Repair (including Ranges and Cooktops))
by kepu 1/8/2019 10:48:17 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
Gas Oven won't heat but broiler and burners work fine (Oven Repair (including Ranges and Cooktops))
by Melissabrooks 3/4/2018 6:42:44 AM(UTC)
Lower Oven won't heat (Oven Repair (including Ranges and Cooktops))
by akai230 11/7/2016 5:26:07 PM(UTC)
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 11/24/2015 7:23:04 AM(UTC)
GE Profile Convection Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by igotboost 8/7/2015 10:38:00 AM(UTC)
Ikea Nutid Wall Oven won't heat (Oven Repair (including Ranges and Cooktops))
by Triciav48 6/29/2015 6:36:33 AM(UTC)
Frigidaire oven won't heat (Oven Repair (including Ranges and Cooktops))
by scottrandel 6/28/2015 4:52:44 PM(UTC)
Lower Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by FrustratedGeminiOven 3/15/2015 10:45:08 AM(UTC)
by trisha57 4/28/2014 10:23:33 AM(UTC)
Top oven won't heat after self cleaning was done (Oven Repair (including Ranges and Cooktops))
by Dede B 4/6/2014 2:22:53 PM(UTC)
by JLH69 4/5/2014 1:10:19 PM(UTC)
Hotpoint Electric Oven Won't heat (Oven Repair (including Ranges and Cooktops))
by krausjw 2/22/2014 10:14:42 AM(UTC)
