frosini
#1 Posted : Monday, October 1, 2018 7:23:00 AM(UTC)
frosini
Views messages in topic : 11
Hello,
My KitchenAid electric oven is over 10 years old, and I had already replaced the control board. Now when starting the oven the control panel lights up, but when I set the function and temperature- No Heat! No bake, no broil, no roast, no convection heat. Have not recently run clean cycle.
Any suggestions where to start?
Thank you,
/Peter F.
frosini
#2 Posted : Monday, October 1, 2018 7:45:03 AM(UTC)
frosini
Thank you for this reply. Can I power the oven off/on then perform the board programming as described in the tech sheet?
/Peter F.
frosini
#3 Posted : Monday, October 1, 2018 8:22:51 AM(UTC)
frosini
I cycled the power off/on then programmed the control board. Still no heat. What is next step: Thermal fuse or temp. sensor?
To be clear, I replaced the oven control board several months ago after erratic oven operation, and it has been working great until now.
TY!
/Peter F.
Billy889
#4 Posted : Monday, October 1, 2018 4:41:03 PM(UTC)
Billy889
Originally Posted by: ohm Go to Quoted Post
Can give you your tech sheet.
+1
UserPostedImage
