JLH69
#1 Posted : 11 years ago
JLH69
Both ovens are not heating. Press the start button for either oven and everything looks normal but neither oven will heat. Lights and fan come on, temperature window says Lo, but no heating at all. Will note that I recently changed out my breaker box. Any chance that changing the box could be related?
#2 Posted : 11 years ago
See the attachment for a tech sheet. It is the closest I could find DHW9.
I am assuming the the Lo means that the ovens are in preheat and never come ready.
I would check the power as the most likely cuprit since you mentioned the breaker box.
It is the 240 volts (L1 to L2) that is important as that is the votage that drives the heating elements.
File Attachment(s):
KEBS277.pdf (379kb) downloaded 4 time(s).
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 4 years ago
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 6 years ago
oven won't heat, replaced element seems to have caused more problems (Oven Repair (including Ranges and Cooktops))
by kepu 6 years ago
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 6 years ago
Gas Oven won't heat but broiler and burners work fine (Oven Repair (including Ranges and Cooktops))
by Melissabrooks 7 years ago
Oven won't heat (Oven Repair (including Ranges and Cooktops))
by mbreihan59 7 years ago
Lower Oven won't heat (Oven Repair (including Ranges and Cooktops))
by akai230 8 years ago
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 9 years ago
GE Profile Convection Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by igotboost 10 years ago
Ikea Nutid Wall Oven won't heat (Oven Repair (including Ranges and Cooktops))
by Triciav48 10 years ago
Frigidaire oven won't heat (Oven Repair (including Ranges and Cooktops))
by scottrandel 10 years ago
Lower Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by FrustratedGeminiOven 10 years ago
by trisha57 11 years ago
Top oven won't heat after self cleaning was done (Oven Repair (including Ranges and Cooktops))
by Dede B 11 years ago
Hotpoint Electric Oven Won't heat (Oven Repair (including Ranges and Cooktops))
by krausjw 11 years ago
