montville524
#1 Posted : Monday, September 10, 2012 7:01:58 AM(UTC)
montville524
I have a problem with the oven not comeing on.The igniter seems to be glowing as brite as the broiler,thats works ok.I can use the broiler to get the oven up to temp. than switch over to the oven.Is the lower igniter bad?.
Simon / APP Team
#2 Posted : Monday, September 10, 2012 10:56:29 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Using the amp meter check the current draw of the bake ignitor.
In order to open the gas valve it should be about 3.2 Amp.
If it's less- replace the ignitor Part number: 318177720
Top Oven Will Not Ignite (Oven Repair (including Ranges and Cooktops))
by tdolecek 8/22/2013 11:46:26 AM(UTC)
Bosch oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Stan Twardowski 4/16/2012 5:57:48 AM(UTC)
OVEN WILL NOT IGNITE (but igniter glows) (Oven Repair (including Ranges and Cooktops))
by dennis728 2/7/2011 5:44:03 PM(UTC)
Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Tracy H 12/19/2010 4:30:33 PM(UTC)
top burners & oven will not ignite (Oven Repair (including Ranges and Cooktops))
by cortlandt32 10/22/2010 5:16:37 AM(UTC)
Oven will not ignite, but broiler does (Oven Repair (including Ranges and Cooktops))
by BillWat 3/28/2010 4:12:20 PM(UTC)
by weberce13 1/12/2010 8:31:07 AM(UTC)
Whirlpool gas range oven will not ignite (Oven Repair (including Ranges and Cooktops))
by kamzuk 1/2/2010 2:59:23 PM(UTC)
storm now oven will not ignite (Oven Repair (including Ranges and Cooktops))
by bonnie32f 8/17/2009 6:48:24 AM(UTC)
by jake59 6/24/2009 9:23:46 AM(UTC)
Gas Range Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Clubogilvie@yahoo.com 3/26/2009 12:03:07 PM(UTC)
Whirlpool gas oven will not ignite (Oven Repair (including Ranges and Cooktops))
by adamerik 11/5/2008 2:34:26 PM(UTC)
by gordo634 7/22/2008 5:45:05 AM(UTC)
Tappan 12-1863-10/03 Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by areamon 6/4/2008 12:36:22 PM(UTC)
Burners and oven will not ignite (Oven Repair (including Ranges and Cooktops))
by bren 7/26/2007 12:32:27 PM(UTC)
