I have a problem with the oven not comeing on.The igniter seems to be glowing as brite as the broiler,thats works ok.I can use the broiler to get the oven up to temp. than switch over to the oven.Is the lower igniter bad?.
Groups: APP Team
Hi. Using the amp meter check the current draw of the bake ignitor. In order to open the gas valve it should be about 3.2 Amp. If it's less- replace the ignitor Part number: 318177720
