billfvib
#1 Posted : Sunday, May 31, 2009 10:54:38 AM(UTC)
billfvib
i HAVE A FRIGIDAIRE MODEL fef389wecc THA TAKES FOREVER TO HEAT UP. THE RELAY ON THE CONTROLE CARD ONLY STAYS ON FOR A FEW SECONDS. THE TOP ELEMENT IS GETTING 240 VOLTS TO IT BUT THE BOTTON GETS ONLY ABOUT 50 VOLTS.
#2 Posted : Sunday, May 31, 2009 12:33:56 PM(UTC)
Replacement parts for FRIGIDAIRE FEF389WECC | AppliancePartsPros.com
Here is a wiring diagram, note it si for wfcc which is the closest I could find
http://manuals.frigidaire.com/p...pringfield/316002638.pdf
Note the parts has a wiring diagram but it is pretty blurry.
The first thing I would check is the temp sensor since the relay is switching the element on/off.
Here is a good site with basic oven repair info
http://www.applianceaid.com/elecrange.html
Check out # 7 & 8
Note that a poor connection can also do this re: the sensor's resistance is directly proportional to the temp so if a bad connection adds resistance to the circuit the control board thinks the oven is hotter than it actually is.
The 50 volts may just be ghost voltage, though it does seem a little high for this or the bake relay contacts are badly pitted dropping the voltage.
SOS - Frigidaire Electric Range not working (Oven Repair (including Ranges and Cooktops))
by Pete11 1/27/2015 8:23:19 AM(UTC)
Frigidaire Electric Range F3 fault code (Oven Repair (including Ranges and Cooktops))
by utahmom 3/31/2014 12:26:01 PM(UTC)
My Frigidaire Electric Range is showing F1 Code. (Oven Repair (including Ranges and Cooktops))
by smieri6 7/20/2013 9:45:09 PM(UTC)
frigidaire electric range (Oven Repair (including Ranges and Cooktops))
by PITMAN 9/29/2011 7:44:11 PM(UTC)
Frigidaire Electric Range - Oven just blew - Top works HELP (Oven Repair (including Ranges and Cooktops))
by Kris&Tara 4/3/2011 6:14:12 PM(UTC)
changing ECU in frigidaire electric range.. quick question (Oven Repair (including Ranges and Cooktops))
by larryk13 3/22/2010 2:52:24 PM(UTC)
Frigidaire Electric Range-- controller 'brains' (Oven Repair (including Ranges and Cooktops))
by larryk13 3/19/2010 7:52:08 AM(UTC)
Frigidaire electric range temperature fluctuations (Oven Repair (including Ranges and Cooktops))
by faisalmali 11/25/2009 4:23:09 AM(UTC)
Frigidaire Electric Range and Cooktop (Oven Repair (including Ranges and Cooktops))
by bboustany 11/7/2009 11:24:31 AM(UTC)
Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by billfvib 5/31/2009 10:50:40 AM(UTC)
1975 Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by BHERNANDEZ3 2/2/2009 7:13:30 AM(UTC)
by Schnidly 5/23/2008 10:40:13 AM(UTC)
