stove and oven elements quit working. clock and lights work. dealer went out of business.:mad:
Here are your parts Replacement parts for FRIGIDAIRE FES365EQA Frigidaire/electric Range | AppliancePartsPros.comHere is the wiring diagram http://manuals.frigidaire.com/p...assomption/318271906.pdfOften this is a power problem as the 240 volts feeding the stove top and oven elements have different controls. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the elements require the full 240 volts. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"] Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
