Dryer starts and runs for awhile then starts making buzzing noise before it stops. After it sits awhile it will restart, but problem will repeat itself a few times before load is done. My guess is either thermostat safety or timer?
Check rear drum support for excessive wear. A dragging drum will cause the motor to overheat and shut down. You may hear a scrapping noise at rear of dryer.
