arrows
#1 Posted : Sunday, November 25, 2007 5:46:07 AM(UTC)
arrows
Dryer starts and runs for awhile then starts making buzzing noise before it stops. After it sits awhile it will restart, but problem will repeat itself a few times before load is done. My guess is either thermostat safety or timer?
jumptrout51
#2 Posted : Sunday, November 25, 2007 6:25:16 AM(UTC)
jumptrout51
Check rear drum support for excessive wear. A dragging drum will cause the motor to overheat and shut down.
You may hear a scrapping noise at rear of dryer.
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Dryer stops running when I release the push to start button (Dryer Repair)
by Guest 6/22/2022 9:57:15 AM(UTC)
GE Spacemaker electric washer dryer stops mid cycle (Dryer Repair)
by nikolait 3/6/2022 11:35:53 PM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Kenmore dryer stops after few minutes with wet light blinking (Dryer Repair)
by mhren 8/19/2017 6:41:02 AM(UTC)
Whrilpool gas dryer stops in heat cycle (Dryer Repair)
by Percy2459 7/6/2017 1:08:27 PM(UTC)
Frigidaire Affinity Dryer stops after about 10 minutes. (Dryer Repair)
by krad 3/1/2017 4:32:58 PM(UTC)
Dryer stops after 20 minutes (Dryer Repair)
by Mr.Ford 2/23/2017 8:31:29 AM(UTC)
by mgbrinkman 2/13/2017 7:56:55 AM(UTC)
Dryer Stops - But Re- Starts Immediately (Dryer Repair)
by pickmari 2/9/2017 7:57:54 AM(UTC)
Dryer stops mid-cycle (Dryer Repair)
by DIYDave 12/10/2016 5:31:36 PM(UTC)
Dryer stops heating (Dryer Repair)
by NYMountainair 7/18/2016 7:29:27 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Dryer stops running after 20 min on heated cycle (Dryer Repair)
by Olaf_sc 11/2/2015 9:05:28 AM(UTC)
