Doesn't matter witch time setting I put my dryer on it shuts off after 20 minutes. Air flow is fine and it does heat up. Can't tell if it's over heating or not.
It does this on timed and sensor dry cycles? If you set it for 45 minutes timed dry it stops at 20 minutes anyway?
