The stove top works, the broiler works, the oven does not always ignite with the first try. Could this be an igniter issue?
Most likely the problem is a bad igniter. - The part number for the oven igniter AP2150412 - Here are the break down diagrams for the Tappan range Model 30-3991-00-02Gene.
Thanks Gene. Do i get to this part from inside the oven?, the back?, front?
