Chuck McCance
#1 Posted : Tuesday, November 20, 2007 4:11:39 PM(UTC)
Chuck McCance
The stove top works, the broiler works, the oven does not always ignite with the first try. Could this be an igniter issue?
#2 Posted : Tuesday, November 20, 2007 4:54:28 PM(UTC)
Most likely the problem is a bad igniter.
- The part number for the oven igniter AP2150412
- Here are the break down diagrams for the Tappan range Model 30-3991-00-02
Chuck McCance
#3 Posted : Tuesday, November 20, 2007 7:27:41 PM(UTC)
Chuck McCance
Thanks Gene. Do i get to this part from inside the oven?, the back?, front?
Tappan oven or broiler won't ignite (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2023 6:57:29 AM(UTC)
Tappan oven is heating higher than set point (Oven Repair (including Ranges and Cooktops))
by Burntfood 7/26/2013 6:45:03 PM(UTC)
Tappan oven won't lite-burners all work fine (Oven Repair (including Ranges and Cooktops))
by Dekimpej 4/6/2012 12:33:22 PM(UTC)
Tappan oven/stove not heating up (Oven Repair (including Ranges and Cooktops))
by billyb133 11/24/2011 3:21:53 PM(UTC)
Tappan Oven Broil Element Problem (Oven Repair (including Ranges and Cooktops))
by mike1937 11/20/2011 1:19:28 PM(UTC)
tappan oven/broiler not working (Oven Repair (including Ranges and Cooktops))
by snowdooer 3/7/2011 4:25:44 PM(UTC)
Tappan Oven and broiler inop (Oven Repair (including Ranges and Cooktops))
by RDSDoug 1/15/2011 9:41:18 AM(UTC)
Tappan oven igniter installation (Oven Repair (including Ranges and Cooktops))
by Just George 11/24/2010 9:44:06 AM(UTC)
Tappan Oven (Oven Repair (including Ranges and Cooktops))
by Hopefloats40 10/19/2010 10:10:49 AM(UTC)
tappan oven (smell gas but won't heat up) (Oven Repair (including Ranges and Cooktops))
by helgalai 8/3/2010 10:57:58 AM(UTC)
Older Tappan oven won't light (Oven Repair (including Ranges and Cooktops))
by cheale 7/19/2010 6:04:09 PM(UTC)
by rddd1313 10/13/2009 7:04:38 PM(UTC)
Older tappan oven over heats (Oven Repair (including Ranges and Cooktops))
by jbarkley123 7/3/2009 9:41:54 AM(UTC)
Old Tappan Oven overheats (Dishwasher Repair)
by jbarkley123 7/1/2009 4:11:56 AM(UTC)
Tappan Oven not heating (Oven Repair (including Ranges and Cooktops))
by evsolo 4/22/2009 11:48:49 AM(UTC)
