Greetings, My washer won't spin or drain, but I hear the motor humming and the timer is clicking away. Any idea?? I tried bypassing the switch located under under the lid with the same results. Thanks
Originally Posted by: mastercylinder ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Greetings, My washer won't spin or drain, but I hear the motor humming and the timer is clicking away. Any idea?? I tried bypassing the switch located under under the lid with the same results. Thanks Mastercylinder, Based on your post, I would have to suspect a bad timer. Presumably, the washer fills and washes, then hums when the spin/drain cycle occurs. You can be 90% sure the motor or pump is OK. and since you bypassed the lid switch assembly, That's where I'd start. Good Luck, :) :) :)
