pdiddy
#1 Posted : Sunday, July 22, 2007 11:43:28 PM(UTC)
pdiddy
Is there an easy way to attach the pump to the motor shaft? I cracked the new pump trying to get it on the motor shaft.
Tech72
#2 Posted : Wednesday, October 7, 2015 9:59:44 PM(UTC)
Tech72
The pump should slide on easily, if it requires force then the motor shaft has rust buildup and will need to be cleaned with a small file and sand paper. Be careful not to remove to much as the two pieced are fitted to prevent slippage and premature pump failure. Once cleaned, apply a very thin coat of grease to the motor shaft to prevent rust and to help with installation.
Hope this helps !!
Washer wont stop draining even after replacing pump (Washer Repair)
by CreativeGirl 5/10/2017 11:59:10 PM(UTC)
LG Washer not draining after replacing pump motor (Washer Repair)
by jrclancyjr 7/12/2014 3:49:04 PM(UTC)
Kenmore Catalyst won't drain after replacing pump (Washer Repair)
by marnidyce 1/20/2013 7:35:17 PM(UTC)
after replacing pump washer cuts itself off after hitting the power and start button (Washer Repair)
by dirty laundry 3/24/2012 5:52:08 PM(UTC)
replacing pump on maytag legacy topload washer thats leaking (Washer Repair)
by scubasteve1234 8/27/2011 4:44:13 PM(UTC)
Replacing Pump Motor on KUDS01FLSS0 (Dishwasher Repair)
by jpbryant 2/22/2010 6:48:49 AM(UTC)
Help Replacing Pump Hose (Washer Repair)
by EnzoMatrix 5/9/2009 10:28:20 PM(UTC)
replacing pump seal in ge dishwasher (Dishwasher Repair)
by cathy037 7/20/2008 11:16:58 AM(UTC)
Need hints on replacing Pump & Motor Assy for Kitchen Aid KUDS dishwasher (Dishwasher Repair)
by rluben 6/20/2008 1:47:21 PM(UTC)
