AppliancePartsPros.com
Appliance Repair Help
Washer Repair
replacing pump on maytag legacy topload washer thats leaking
washer is leaking i took off the front panel ran washer and water is squirting and leaking from pump area ,i need tips or some step by step on replacing pump i ordered a new pump from appliance parts pros
You have to take out the motor on this model to replace the pump. It is not hard, but it is awkward and you should have some help because the motor is heavy
Once it is out you can remove the pump and replace it. Make sure you note how the belt and idler go so you can put them on the right way. Take some photos if you need to.
Washer Repair
