Ed
EJO
#1 Posted : Saturday, October 9, 2010 7:47:09 AM(UTC)
EJO
Microwave is just over 5 years old and food will not heat up. I have heard that it may be the door sensor switch or door monitor that is defective. Is there any way to test either one before ordering a new part. :)
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
Belarus fixitboy 7/3/2024 1:06:24 PM(UTC)
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
OLD FRIDGEDAIRE OVER & UNDER GLRT214RAW4 (Refrigerator & Freezer Repair)
by brou102 6/29/2024 10:51:20 AM(UTC)
Bosch sprayer channel clip spot weld failed on back wall (Dishwasher Repair)
by Billymons 6/15/2024 5:23:17 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Restricted airflow after repairman installed new blower wheel (Dryer Repair)
by Guest 6/1/2024 5:28:38 PM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Water tube disconnected (Refrigerator & Freezer Repair)
by Guest 5/31/2024 11:41:13 AM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
Diagnostic Code Help (I screwed something up) (Refrigerator & Freezer Repair)
by megarms 5/20/2024 7:30:54 AM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
