Guest
#1 Posted : Friday, May 31, 2024 11:41:13 AM(UTC)
Guest
Groups: Guests
Hey Appliance Parts Pros.
I have a Fridgidaire built in side by side (KSSC48QTS) that is leaking water. I lifted the fridge and found a water tube seeking a place to hook in. Ice sucks in the water without any leaks so this tube is only meant for the water dispenser. On the bottom, the tube comes from the front right and seemingly is supposed to end up in the front left somewhere. I don't see anywhere this can be attached. I hate calling for help so this is the step before that :) Any advice on how I can find the connector this tube belongs to?
Thanks in advance.
Edited by user Friday, May 31, 2024 11:42:01 AM(UTC)  | Reason: Not specified
WilliamM/APP Team
#2 Posted : Saturday, June 1, 2024 5:20:32 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
Was thanked: 14 time(s) in 14 post(s)
There should be tubing coming out of the freezer door hinge with a connector on it where the tubing from the right would connect. If the tubing at the door is missing or broken, the freezer door W10162569 would need to be replaced. Unfortunately, this has been discontinued by the manufacturer and is no longer available.
