Joined: 6/10/2024(UTC) Posts: 0  Location: California
The microwave light bulb on this 20+ years old Whirlpool Oven/Microwave wall-mounted combo ModelGMC305PDB2 has failed. I need to figure out how to pull out the microwave to replace the light bulb on top. I had seen a video some 10 years ago but can't find it any longer. EDIT: Found a fairly close video here and accessed the light bulb. The circuit indicates it is the only item using the 12V output of a dedicated transformer. Steps: 1- Remove two screws holding each of the side trims. Pry the trim out by sliding it down. 2- Remove the two side screws to disengage the interface panel. 3- Remove the microwave vent grill. 4- Remove the oven vent grill. 5- Remove two screws holding the microwave in place. Pull the microwave about 1/2 way out. 6- Remove the spring clip holding the lamp assembly. 7- Replace the halogen lamp without touching its surface with bare hands. 8- Follow the steps in reverse to put everything back together. Edited by user Monday, June 10, 2024 6:14:12 PM(UTC)
| Reason: Solved update
Joined: 5/12/2024(UTC) Posts: 0  Location: Ontario Was thanked: 10 time(s) in 10 post(s)
Hi,
That should help others....thankx!
jeff sr. |
