NevadaBill
#1 Posted : Monday, July 3, 2017 7:54:11 AM(UTC)
NevadaBill
Whirlpool Duet Sport washer (WFW8500SR00) stopping with F-01 error code with about 8 minutes remaining in the final spin cycle. I have unplugged the machine, waited a few minutes a plugged it back in but the problem still occurs. Any suggestions?
PNWDrew
#2 Posted : Monday, July 3, 2017 12:33:31 PM(UTC)
PNWDrew
You have probably found the description of that code through Google by now but basically it means that the relay that powers the pump has failed. Or at least the computer thinks it has. Sometimes if you get lucky it is the actual pump but that's not very common.
Most of the time that would mean a new main control. You can check the pump operation during test but that is not going to run the pump as long as an actual cycle would.
If you have a multimeter you can monitor that pump voltage as it approaches the eight minute mark and see if it gets weird and shows 30 volts or something like that. Often when relays fail they deliver low or unusual voltage. You can also check the resistance of the pump motor to verify that it is not shorted or otherwise faulty. I think you're looking for around 12 ohms on that motor.
Guest (5)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
GE washer stops mid cycle (Washer Repair)
by APPLIANCEDUDE1972 3/4/2015 6:32:45 AM(UTC)
Dishwasher stops mid cycle (Dishwasher Repair)
by vpchianese 11/15/2013 2:32:24 PM(UTC)
Maytag washer stops mid cycle (Washer Repair)
by paubert03 12/2/2012 3:33:21 PM(UTC)
Washer stops mid cycle (Washer Repair)
by dideyjohn 11/27/2012 6:06:54 PM(UTC)
by tedwards353 2/20/2012 10:21:16 AM(UTC)
by maryprice4 10/17/2011 6:29:09 PM(UTC)
by ncdunn 3/31/2011 6:55:03 PM(UTC)
by krislinda 11/9/2010 12:52:34 PM(UTC)
Whirlpool Washer Stops Mid Cycle (Washer Repair)
by cfphillips 9/3/2010 11:01:15 AM(UTC)
by Dave W. 6/7/2010 10:59:53 AM(UTC)
Maytag SE 1000 washer stops mid cycle or won't start wash cycle (Washer Repair)
by katyat 9/10/2009 1:23:57 PM(UTC)
by CLK 7/19/2009 11:03:25 PM(UTC)
Frigidaire diswasher stops mid cycle (Dishwasher Repair)
by bhacker 7/17/2009 3:58:44 AM(UTC)
Whirlpool washer stops mid cycle (Washer Repair)
by kgundi 6/5/2009 7:39:39 AM(UTC)
