the machine stopped mid-cycle in the rinse mode... will not do anything but fill on rinse, when it gets to pump out the water, it stops. It is not the timer, which I guessed it was, I replaced that.
Check the lid switch. If that is not the problem post back to us with as detailed a description of the problem as possible, whether or not it happens in all cycles and what happens when you manually move the timer.
sorry, your reply found its way into spam... got irritated and bought new machine... not lid switch... would fill and agitate then stop, pump worked for a second, then nothing... figured it was either expensive or beyond me.... thanks much for the help
Probably a good idea, good luck with your new machine and thanks for updating us.
