rwseeley
#1 Posted : Thursday, October 1, 2015 4:20:52 AM(UTC)
rwseeley
the machine stopped mid-cycle in the rinse mode... will not do anything but fill on rinse, when it gets to pump out the water, it stops. It is not the timer, which I guessed it was, I replaced that.
sidfink43
#2 Posted : Thursday, October 1, 2015 4:11:29 PM(UTC)
sidfink43
Check the lid switch. If that is not the problem post back to us with as detailed a description of the problem as possible, whether or not it happens in all cycles and what happens when you manually move the timer.
rwseeley
#3 Posted : Tuesday, October 6, 2015 11:36:38 AM(UTC)
rwseeley
sorry, your reply found its way into spam... got irritated and bought new machine... not lid switch... would fill and agitate then stop, pump worked for a second, then nothing... figured it was either expensive or beyond me.... thanks much for the help
sidfink43
#4 Posted : Tuesday, October 6, 2015 12:34:53 PM(UTC)
sidfink43
Probably a good idea, good luck with your new machine and thanks for updating us.
Dishwasher stops in middle of cycle and has draining problems (Dishwasher Repair)
by Guest 12/21/2022 1:34:11 PM(UTC)
Whirlpool Cabrio Washer Stops Intermittently (Dishwasher Repair)
by Amadago76 4/1/2022 9:57:02 AM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Frigidaire FTF530 Washer Stops Randomly During Wash Cycle (Dishwasher Repair)
by jensenpe 10/11/2021 7:28:24 AM(UTC)
Bosch dishwasher stops at beginning of cycle (Dishwasher Repair)
by Daniel J 2/23/2021 10:39:24 PM(UTC)
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Washer Stops Spinning Abruptly or Doesn't Spin At All (Washer Repair)
by ggarcia 3/28/2020 9:20:13 AM(UTC)
Maytag dishwasher stops filling then shuts down (Dishwasher Repair)
by fordguy101 11/2/2018 6:58:19 PM(UTC)
Washer stops agitating mid cycle - F7E5 shifter fault (Washer Repair)
by Phil915 9/15/2018 2:45:38 PM(UTC)
Washer stops mid cycle (Washer Repair)
by NevadaBill 7/3/2017 7:54:11 AM(UTC)
Maytag Centennial Washer Stops Mid-Cycle (Washer Repair)
by washer2017 3/16/2017 5:58:01 AM(UTC)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
Washer Stops before pump and spin (Washer Repair)
by tomwing 3/25/2016 1:40:09 PM(UTC)
Maytag washer stops agitating in wash cycle (Washer Repair)
by Teggy87 12/6/2015 8:51:20 AM(UTC)
Washer Stops during Sensing Mode (Washer Repair)
by gotimmygo89 10/5/2015 7:12:57 AM(UTC)
