Rank:: Member
My washer starts up and goes through the wash cycle and then stops and within a few minutes of stopping I checked the three main valves resistance o see if any of them have open loop, nothing. Is it the man circuit board? Don't want to order it f I do not have to. We have plenty of water pressure - 50 pisg coming into house
This model has two control units, a main control unit and a speed/motor control unit.
Look inside the lower service panel for tech notes that will tell you how to do some testing on each one. At the end of the day however you may just have to replace each one to see which one is the problem. If you buy from this site you can return the part you do not need.
Also, the door lock mechanism can be a problem, so check it out also.
