duffybpp
#1 Posted : Thursday, August 30, 2012 3:28:44 AM(UTC)
duffybpp
I have just received my brand new Whirlpool Clothes Washer. I got a fright the first day I went to use it. When I opened the door to put clothes in water poured out of the drum onto the floor. I thought maybe there was water in the drum which leaked in during installation. I then washed some clothes on the normal cycle and went to bed. The next morning I opened the door of the washer to take out the clothes to put them in the dryer and water POURED out the door again ! Each of these times I closed the door and ran the shorter spin cycle to get rid of the water.
Yesterday I ran another load to test what was going on. The normal cycle ran to completion but when I opened the door and checked the clothes I found water was still in the bottom of the drum. I decided to leave it overnight to see if any more water collected. Well it did ! I went to bed with water in the bottom of the drum and this morning it was visible through the door as being half way up the drum.
My husband has rechecked the hook up twice and found no problem. Can you tell me what the problem might be ?
Simon / APP Team
#2 Posted : Thursday, August 30, 2012 11:39:23 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You may have the high water pressure or defective water inlet valve.
First have a plumber check the pressure and if that is OK - call for the warranty repair.
Simon.
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
clothes washer don't work, troubleshooting manual wtw5500xw0 cabrio (Washer Repair)
by paulmars 4/2/2022 10:43:24 AM(UTC)
Kitchenaid clothes washer (Washer Repair)
by 76 Terra 1/24/2022 10:05:31 AM(UTC)
Clothes Washer (Washer Repair)
by jogrodz 4/2/2018 6:36:28 AM(UTC)
clothes washer only leaks when filling (Washer Repair)
by elijahfischer 8/22/2013 7:06:46 AM(UTC)
Maytag clothes washer (Washer Repair)
by fnolen 7/21/2013 3:04:54 PM(UTC)
Kitchenaid clothes washer won't spin without a push (Washer Repair)
by dlunde 5/29/2013 5:23:00 PM(UTC)
GE Clothes washer won't advance to wash cycle (Washer Repair)
by Zog 2/11/2013 4:33:01 PM(UTC)
by louis Dionise 12/14/2012 10:40:32 AM(UTC)
Clothes Washer Lint Issue (Washer Repair)
by kenmoregator 11/30/2012 3:01:10 AM(UTC)
Whirlpool Clothes Washer (Washer Repair)
by DirtyClothes1 7/7/2012 4:01:42 PM(UTC)
lint clothes washer (Washer Repair)
by paulmars 3/16/2012 4:21:12 PM(UTC)
Whirlpool Clothes Washer time won't advance (Washer Repair)
by djaco4749 3/9/2012 8:11:44 AM(UTC)
Clothes Washer won't spin clothes dry (Washer Repair)
by JCHD 1/26/2012 7:09:42 AM(UTC)
by cktab 11/22/2011 6:39:43 PM(UTC)
