When the drum starts to turn there is a squeeling noise from the front of the drum. If i reach inside i can move the drum up and down. What supports the frontof the drum?
scott if the drum moves that much you would be best to replace the rear drum bearing, and the front glides. there are 2 different glides on the front. the part # on the glides are we1m481, and we1m333, and you will need 2 of each. also the rear bearing kit part # is we25m40. these parts are not expensive, and it would be worth fixing. tom [url=]applianceeducator.com - parts[/url]
