SCOTT CAMERON
#1 Posted : Wednesday, February 11, 2009 3:40:47 PM(UTC)
SCOTT CAMERON
When the drum starts to turn there is a squeeling noise from the
front of the drum. If i reach inside i can move the drum up and down.
What supports the frontof the drum?
kayakcrzy
#2 Posted : Thursday, February 12, 2009 3:58:37 AM(UTC)
kayakcrzy
scott if the drum moves that much you would be best to replace the rear drum bearing, and the front glides. there are 2 different glides on the front. the part # on the glides are we1m481, and we1m333, and you will need 2 of each. also the rear bearing kit part # is we25m40. these parts are not expensive, and it would be worth fixing. tom [url=]applianceeducator.com - parts[/url]
Knocking noise from my ge gas dryer. (Dryer Repair)
by Lougaal 2/16/2023 9:40:08 AM(UTC)
GE gas dryer rattling (Dryer Repair)
by johno1947 4/24/2017 4:11:51 PM(UTC)
GE gas dryer heats for a few minutes, then goes cold (Dryer Repair)
by swapped 9/24/2015 9:31:14 AM(UTC)
Weird, GE gas dryer not keep running (Dryer Repair)
by techlover 8/6/2015 8:14:16 AM(UTC)
GE Gas Dryer Igniter Glows but No Flame (Dryer Repair)
by kwillindy 5/4/2015 9:21:49 AM(UTC)
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 1/23/2015 5:38:59 PM(UTC)
GE gas dryer on/off button (Dryer Repair)
by phillipj 1/10/2015 3:00:35 PM(UTC)
GE Gas dryer (Dryer Repair)
by cstellar 12/22/2014 10:46:32 AM(UTC)
GE Gas Dryer Error Code E01 & Stopped intermittently (Dryer Repair)
by bhurlbert 4/21/2013 5:43:49 PM(UTC)
GE gas dryer won't stay on (Dryer Repair)
by Bearjohnson 2/26/2013 10:36:11 PM(UTC)
ge gas dryer trips fuse after installing ignitor (Dryer Repair)
by lucyfoot 2/25/2013 3:19:07 PM(UTC)
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
ge gas dryer no heat (Dryer Repair)
by mdelgiu1 11/7/2012 1:23:14 AM(UTC)
GE Gas Dryer - Drum Won't Turn / Locked Up (Dryer Repair)
by roma1625 10/31/2012 9:52:33 AM(UTC)
Ge gas dryer no heat (Dryer Repair)
by moby2000 10/25/2012 9:04:28 AM(UTC)
